Guac HTML5 option for controlling VM not showing in GUI
I’m referring to the RDP with FireEdge section (Managing Virtual Machines Instances — OpenNebula 6.0.4 documentation)
The connect via browser option is not showing in the instances tab. I would like to retrieve hyperlinks to access virtual machines, for virtual desktop distribution. The hyperlinks would be used by non-opennebula users, are there any other options I should explore?
The opennebula-fireedge and opennebula-guacd services are running, I tried to install apache guacamole separately and edit the fireedge-server.conf file and uncommenting the “guacd:” part
Hello @anoesheartje ,
To connect via browser from Sunstone, you have two options:
  • Enable the paremeter get_extended_vm_info in sunstone conf. Remember restart Sunstone service after changes.
  • Through the detailed view of the VM, at the top you should see a blue dropdown button with the remote connections availables.
Best,
Sergio
Hello @sbetanzos ,
This worked for me, thank you very much!
