Well I have the OpenNebula installed on a vm with in my infrastructure but I am having issues adding my hosts to the frontend.
I have chacked the ~/.one/one_auth file on the frontend and the intended node and the passwords are the same however I changed my password in the GUI after I first got logged on
This is the error I get at the cli trying to add one of my hosts
onehost create farragut -i kvm -v kvm -n dummy [HostAllocate] User couldn’t be authenticated, aborting call.
Just not sure what is causing this, and before you ask yes I have googled it several times and got things that really didn’t make sense to me.
Yes, authentication can be annoying, but it’s there for a reason… My guess is that the VirtualMachinePoolInfo calls are failing because the scheduler was launched before the oneadmin password was changed in one_auth. Try restarting the opennebula service.
Thanks again, It appears that this is still an issue after
restarting OpenNebula Service and rebooting the host box to have a clean
slate. I will have to keep researching,
I am a noob so I am still learning how to diagnose and work in the
OpenNebula environment.
By the way I am going to try to install it on CentOS as the frontend and
see if that works any better. Right now I am an all Ubuntu 14.04 and 15.04
Shop so-to-speak.
