Hi Team,
I am trying to make Host in Opennebula, but I am getting the error:
Error (170.4 KB)
Initializing (150.8 KB)
i checked the log file too. log file is as follows:
Error1 (241.8 KB)
Please Suggest.
Hi Team,
Error (170.4 KB)
Error1 (241.8 KB)
Please Suggest.
Error2 (157.3 KB)
Error3 (249.5 KB)
you must be able to log in as oneadmin user from Host A to every other host (including Host A itself). The same goes for every other host.
How to do this is described here:
http://docs.opennebula.org/5.2/deployment/node_installation/kvm_node_installation.html#step-4-configure-passwordless-ssh
I hope this solves your problem.
Bernhard
Thanks Bernhard…
Just a small confusion about this line:
I did only for the nodes, but if I do ssh FRONTEND then I am getting this error:
Please Suggest.
you have problem with ssh it is not about opennebula now
make sure that 192.168.17.131 has user oneadmin and openssh-server installed
forget now about opennebula script
when u ask ssh 192.168.17.131 it should make connection and ask you for password
let now think as u just want to shh 192.168.17.131
first 192.168.17.131 should be reached try to ping
and when u try make ssh 192.168.17.131 from 192.168.17.130
it same as ssh oneadmin@192.168.17.131 so user oneadmin should be exist on 131 and openssh-server install 192.168.71.131
make sure the firewall if exist allowe port 22 ssh port
Respected Ghaleb,
192.168.17.131 is reachable from 192.168.17.130. Following is the screenshot of 192.168.17.130 when tried to ping to 192.168.17.131:
And when I try to make ssh 192.168.17.131 from 192.168.17.130, following comes:
Firewall for frontend i.e. 192.168.17.131 and node i.e. 192.168.17.130 are off.
User oneadmin exists on 192.168.17.131. Moreover I am able to add hosts too. i have added two machines as hosts 192.168.17.130 and 192.168.17.129 and these two are up.
I think automatically SSH Passwordless is not working. I have added manual keys as suggested by Mr. Bernhard above:
http://docs.opennebula.org/5.2/deployment/node_installation/kvm_node_installation.html#step-4-configure-passwordless-ssh1
But how I can configure auto SSH Passwordless? Also how to configure frontend and nodes so as I can ssh 192.168.17.131 from 192.168.17.130 ?
if ssh passwordless field ssh will not stop it just will ask for password
try ssh oneadmin@192.168.17.131 i think same error will face but just make sure
first let access the fronend with password than will make it passwordless
I tried doing ssh oneadmin@192.168.17.131 from 192.168.17.130 (node) and I got the same response:
post your
cat /etc/passwd form 192.168.17.131
what you mean add host if you mean change /etc/hosts it is nothing about ssh now later we need it since opennebula talk with host not with ip
you are new in linux cat /etc/passwd from 192.168.17.131
or i miss to said my point
go to server or node 192.168.17.131 and give out put of cat /etc/passwd
i cant see why you cant access maybe
More than one computer on the network has the same IP as the server causing an IP conflict
Wrong username or your credentials have been revoked
and you dont try
https://opennebula.org/tryout/
it not easy to run opennebula
Respected Ghaleb Ji,
I am able to run opennebula. I think you took the case in some other direction.
My query is I am not able to ssh 192.168.17.131 (frontend), whereas I am able to ssh to all the nodes. I am not sure if this is required or this happens this way only?
sure it reuired
try arping 192.168.17.131
this will tell you if there is more than one pc with same ip
it is network issue or issue with 192.168.17.131
Yes Ghaleb Ji.
So My problem is I am not able to ssh 192.168.17.131 (frontend), whereas I am able to ssh to all the nodes. I am getting ‘connection refused’ when I do ssh from Node to server.
As suggested, I tried performing arping 192.168.17.131, and I got the following output:
After this nothing happens. I waited for more than 30 minutes.
