Hi All,
I am trying to understand datastores on an ON cluster, how they are configured, “backed” their underlying filesystems.
There are two nodes configured to run VMs, node1 and node2
There is a front end configured
The context within which I am trying to understand this is as follows: It is not possible to do the following:
- Deploy VMs on Node2 using Sunstone.
Error copying FRONTEND:/var/lib/one//datastores/1/96b9f5033d196706b6fcc9084e00cb93 to node02:/var/lib/one//datastores/101/<vmid>/disk.0
By FRONTEND, I mean the hostname of the front end.
On FRONTEND, I have checked the directory contents of /var/libe/one/datastores/1
-rw-r--r-- 1 oneadmin oneadmin 376569856 Nov 21 15:35 3c90be75f40cb659daadb8e4d5fe855d
-rw-r--r-- 1 root root 11213471744 May 15 2022 Rocky-8.6-x86_64-dvd1.iso
So the /var/lib/one//datastores/1/96b9f5033d196706b6fcc9084e00cb93 image referenced doesn’t even exist. I suspect that is indeed the problem.
The outputs of onedatastore are as follows:
ID NAME SIZE AVA CLUSTERS IMAGES TYPE DS TM STAT
102 data2 - - 0 0 sys - ssh on
101 data1 - - 0 0 sys - ssh on
2 files 50.4G 71% 0 0 fil fs ssh on
1 default 50.4G 71% 0 16 img fs ssh on
I suspect that the datastore with the ID ‘1’, is backed by /var/lib/one//datastores/1 directory on FRONTEND, however there is a glaring discrepancy here between what is reported usng Sunstone/onedatastore and a directory listing of /var/lib/one//datastores/1
Further information about the datastore 1 I am referring to:
[root@pdl-app-on-prod-01 1]# onedatastore show 1
DATASTORE 1 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : fs
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/1
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 50.4G
FREE: : 35.8G
USED: : 14.6G
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="NO"
CLONE_TARGET="SYSTEM"
DISK_TYPE="FILE"
DS_MAD="fs"
LN_TARGET="SYSTEM"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
TM_MAD="ssh"
TYPE="IMAGE_DS"
IMAGES
0
1
2
3
4
5
6
7
8
9
16
17
18
19
22
29
I’d like to see if someone can confirm whether my interpreation makes sense, and whether anyone can see any problems with anything that I have missed if that’s OK please? Perhaps some more information is needed, before someone can help further…
A database restore was applied to mysql running on FRONTEND, which came from a backup of a previously running FRONTEND (an old front end), would this be the cause of the discrepancy?
Many Thanks!
