i have installed as per quickguide on 1 frontend server and 1 worker. VM is stuck in pending state:
i gave 3 DS in sunstone as per default
pls help - thank you
LOG:
Mon Jul 27 11:04:38 2015 [SCHED][I]: VM 9: No suitable System DS found for Host: 0. Filtering out host.
Mon Jul 27 11:06:05 2015 [VM][D]: Pending/rescheduling VM and capacity requirements:
VM CPU Memory System DS Image DS
10 10 131072 40 DS 1: 0
Mon Jul 27 11:06:06 2015 [HOST][D]: Discovered Hosts (enabled):
0
Mon Jul 27 11:06:06 2015 [SCHED][I]: Scheduling Results:
Virtual Machine: 10
PRI ID - HOSTS
0 0
PRI ID - DATASTORES
0 0
