I want to add some hyperlink in Opennebula end user tabs .
Please let me know which file i need to edit to achieve this task .
I have followed the docs but new changes are not visible
i have restart the opennebula servers also
is it any other service i need to look
Hi Ranveer,
Please elaborate a little bit further - what changes you’ve done what steps followed to enable the changes?
From my experience I could guess that something in Modifying JS & CSS files went wrong.
Kind Regards,
Thanks for your replay
I just want to remove some tabs or drop down menu from the new image creation tab, like thick, thin etc,
i don’t want the end user to select these all fields instead of that i just want to remove all fields so end user will not confuse, i have tried to changes /usr/lib/one/sunstone/public/app/tabs/image some tabs and restart the opennebula service but all fields are same no changes.
Hi Ranveer,
In brief - you should enable the developer mode of sunstone or rebuild the minified js files. For more details how to do that please follow the link in my previous post.
Kind Regards,
