esfreire
(Esteban Freire)
January 21, 2016, 4:00pm
1
I would like to know if it is possible to enable qxl paravirtual graphic card when selecting VNC for KVM VMs. I see that is the default option for spice on /etc/one/vmm_exec/vmm_exec_kvm.conf file but I would like to know if there is a way also to make it the default option for VNC or a workaround to make it possible.
Thanks in advance,
Esteban
jfontan
(Javi Fontán)
January 22, 2016, 9:40am
2
You can add in /etc/one/vmm_exec/vmm_exec_kvm a RAW parameter with the video card:
RAW="<devices>
<video>
<model type='qxl' heads='1'/>
</video>
</devices>"
If you are also going to use spice make sure to take the video option out from SPICE_OPTIONS or it will be added twice.
esfreire
(Esteban Freire)
January 22, 2016, 3:59pm
3
Hi Javi,
Thank you very much for your answer
I think I must be doing something wrong because I still see Cirrus as VGA:
lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 VGA compatible controller: Cirrus Logic GD 5446
00:03.0 Ethernet controller: Red Hat, Inc Virtio network device
00:04.0 SCSI storage controller: Red Hat, Inc Virtio block device
00:05.0 Unclassified device [00ff]: Red Hat, Inc Virtio memory balloon
I see the options appear on the deployment file but I don’t know why the VM is not seeing it:
cat deployment.0
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
<name>one-185</name>
<vcpu>4</vcpu>
<cputune>
<shares>4096</shares>
</cputune>
<memory>8388608</memory>
<os>
<type arch='x86_64'>hvm</type>
<boot dev='hd'/>
</os>
<devices>
<emulator>/usr/bin/qemu-kvm</emulator>
<disk type='file' device='disk'>
<source file='/var/lib/one//datastores/100/185/disk.0'/>
<target dev='vda'/>
<driver name='qemu' type='qcow2' cache='none'/>
</disk>
<disk type='file' device='cdrom'>
<source file='/var/lib/one//datastores/100/185/disk.1'/>
<target dev='hda'/>
<readonly/>
<driver name='qemu' type='raw'/>
</disk>
<interface type='bridge'>
<virtualport type='openvswitch'/>
<source bridge='ovsbridge0'/>
<mac address='04:09:92:65:3b:1b'/>
<model type='virtio'/>
</interface>
<graphics type='vnc' listen='0.0.0.0' port='6085'/>
</devices>
<features>
<acpi/>
</features>
<cpu mode='host-model'></cpu>
<metadata>
<system_datastore>/var/lib/one//datastores/100/185</system_datastore>
</metadata>
</domain>
And indeed, I needed to take the video option out from SPICE_OPTIONS otherwise the VNC does not work.
Any hint on this is welcome
Thanks in advance,
Esteban
jfontan
(Javi Fontán)
January 22, 2016, 7:05pm
4
Check that there’s only one RAW parameter. In case you already have one merge it in only one. I think that this line is already in a RAW parameter:
Merged it should be something like this:
RAW="
<devices>
<video>
</video>
</devices>"
esfreire
(Esteban Freire)
January 27, 2016, 10:21am
5
Hi Javi,
Thank you very much for your answer. I have been making several tests, but unfortunately, it is not working. This is what I have:
EMULATOR = /usr/bin/qemu-kvm
OS = [ boot = "hd", arch = "x86_64" ]
FEATURES = [ PAE = "no", ACPI = "yes", APIC = "no", HYPERV = "no" ]
DISK = [ driver = "raw" , cache = "none", DEV_PREFIX = "vd" ]
NIC = [ model="virtio" ]
RAW="<devices>
<video>
</video>
</devices>"
HYPERV_OPTIONS="<relaxed state='on'/><vapic state='on'/><spinlocks state='on' retries='4096'/>"
And this is the KVM deployment file built:
cat deployment.0
<name>one-198</name>
<vcpu>4</vcpu>
<cputune>
</cputune>
<os>
<boot dev='hd'/>
</os>
<devices>
<source file='/var/lib/one//datastores/100/198/disk.0'/>
<target dev='vda'/>
</disk>
<source file='/var/lib/one//datastores/100/198/disk.1'/>
<target dev='hda'/>
<readonly/>
</disk>
<mac address='04:09:92:65:3b:1d'/>
</interface>
<graphics type='vnc' listen='0.0.0.0' port='6098'/>
</devices>
<features>
<acpi/>
</features>
<devices>
<video>
</video>
</devices>
<metadata>
<system_datastore>/var/lib/one//datastores/100/198</system_datastore>
</metadata>
</domain>
Probably, I am doing something wrong but I would appreciate any help on it since we would like to set up the qxl and also with:
"<cpu mode='host-passthrough'></cpu>"
Thanks in adance,
Esteban
jfontan
(Javi Fontán)
January 27, 2016, 11:51am
6
I can see the video stanza in the deployment file:
<features>
<acpi/>
</features>
<devices>
<video>
</video>
</devices>
<metadata>
</metadata>
Have you tried adding the RAW parameter with both cpu and video from my last post?
esfreire
(Esteban Freire)
January 29, 2016, 7:05am
7
Hi Javi,
Yes, your example was the first I have tried , but it does not work for me and I also have tried with your example and host-passthrough:
But I did not get success.
Thanks in advance,
Esteban
