Hi;
I got thoese errors;
Thu Sep 9 23:02:28 2021 [Z0][TrM][D]: Message received: TRANSFER SUCCESS 10 -
Thu Sep 9 23:02:28 2021 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Thu Sep 9 23:02:28 2021 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Thu Sep 9 23:02:28 2021 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Thu Sep 9 23:02:28 2021 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one/vms/10/vm.xml.
Thu Sep 9 23:02:28 2021 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one/vms/10/ds.xml.
Command execution failed (exit code: 255): /var/lib/one/remotes/vmm/vcenter/deploy ‘/var/lib/one/vms/10/deployment.0’ ‘Lab-Cluster’ 10 Lab-Cluster
Thu Sep 9 23:02:32 2021 [Z0][VMM][E]: deploy: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #0.
Thu Sep 9 23:02:32 2021 [Z0][VMM][I]: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #0. [”/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:63:in parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:92:in call’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:213:in _call'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:76:in block (2 levels) in init’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:191:in _get_property'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:37:in block (2 levels) in init’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:896:in vcenter_folder'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:635:in clone_vm’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3462:in block in new_from_clone'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in tap’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in new_from_clone'", "/var/lib/one/remotes/vmm/vcenter/deploy:88:in '”]
Thu Sep 9 23:02:32 2021 [Z0][VMM][E]: deploy: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #1.
Thu Sep 9 23:02:32 2021 [Z0][VMM][I]: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #1. [”/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:63:in parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:92:in call’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:213:in _call'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:76:in block (2 levels) in init’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:191:in _get_property'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:37:in block (2 levels) in init’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:896:in vcenter_folder'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:635:in clone_vm’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3462:in block in new_from_clone'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in tap’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in new_from_clone'", "/var/lib/one/remotes/vmm/vcenter/deploy:88:in '”]
Thu Sep 9 23:02:32 2021 [Z0][VMM][E]: deploy: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #2.
Thu Sep 9 23:02:32 2021 [Z0][VMM][I]: Deploy of VM 10 on vCenter cluster Lab-Cluster with /var/lib/one/vms/10/deployment.0 failed due to “ManagedObjectNotFound: The object ‘vim.VirtualMachine:’ has already been deleted or has not been completely created"on attempt #2. [”/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:63:in parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/connection.rb:92:in call’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:213:in _call'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:76:in block (2 levels) in init’”, “/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:191:in _get_property'", "/usr/share/one/gems-dist/gems/rbvmomi-2.2.0/lib/rbvmomi/basic_types.rb:37:in block (2 levels) in init’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:896:in vcenter_folder'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:635:in clone_vm’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3462:in block in new_from_clone'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in tap’”, “/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:3461:in new_from_clone'", "/var/lib/one/remotes/vmm/vcenter/deploy:88:in '”]
Thu Sep 9 23:02:33 2021 [Z0][ReM][D]: Req:7968 UID:0 IP:127.0.0.1 one.hostpool.info invoked , -2, -1, -1
Thu Sep 9 23:02:33 2021 [Z0][ReM][D]: Req:7968 UID:0 one.hostpool.info result SUCCESS, “<HOST_POOL><ID…”
Thu Sep 9 23:02:33 2021 [Z0][ReM][D]: Req:9408 UID:0 IP:127.0.0.1 one.host.info invoked , 0, false
Thu Sep 9 23:02:33 2021 [Z0][ReM][D]: Req:9408 UID:0 one.host.info result SUCCESS, “0<NAM…”
Thu Sep 9 23:02:33 2021 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Thu Sep 9 23:02:33 2021 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Thu Sep 9 23:02:33 2021 [Z0][IPM][D]: Message received: DEPLOY FAILURE 10 -
