I’m struggling to install opennebula 4.14 on my Ubuntu wily (15.10) system.
When I do everything as it is described in the quickstart guide for 15.04 I stuck when I try to install opennebula using apt-get.
This is what I get:
The following packages have unmet dependencies:
opennebula : Depends: liblog4cpp5 but it is not installable
Depends: libxmlrpc-c++8 but it is not installable
When I try to install the dependencies separately the result is:
Package liblog4cpp5 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
liblog4cpp5v5:i386 liblog4cpp5v5
After doing some research the only fix I found was to install the packages manually.
Is that still the only solution for that problem?
I can’t install an older version since in need to use the GPU virtualisation.
thanks for posting this, I was just wondering if I should install my customers 2 new Servers with Ubuntu 16.04.
So I will stick with 14.04 and the opennebula 4.14 packages. seems like the best bet at the moment.
