Problem to Upgrade Opennebula from v4.10 to v4.12
Hello Community
I’ve installed opennebula v4.10 and i’m trying to upgrade to v4.12 on Ubuntu 12.04. I have the repository http://downloads.opennebula.org/repo/4.12/Ubuntu/12.04 but when i run apt-get i receive a message that there aren’t any new package to download.
Thank you for your support,
Marcos Torres, Orlando Elvis
Hi Orlando
Take a look for the repository, you have the 4.10 branch on your repository
and you need the 4.12
El 17/03/2015 23:46, “Orlando Marcos Torres” forum@opennebula.org
escribió:
Hi Skymix:
Excuse me, the URL that i was using for upgrade http://downloads.opennebula.org/repo/4.12/Ubuntu/12.04
Thank you,
Unfortunately we stopped packaging for Ubuntu 12.04 in release 4.12.
Hi Javi
So, would I have to upgrade my Ubuntu if i want to upgrade Opennebula to v4.12 ?
Regards,
Upgrade or compile the software manually. But we don’t recommend compiling the software unless you are used to the software itself and the compilation options.
Hello Javi:
It means that nebula will not continue supporting 12.04 or only we have to wait some time until you fix/publish some issue with the repository or something like that.
I would like to know that to plan the upgrade of my nebula servers to 14.04 if you do not continue supporting 12.04.
It means that we won’t support or create new packages for Ubuntu 12.04 from now on. Making packages for a distro means also testing, changing configuration options to accommodate that specific version, etc. That’s why we had to stop supporting some old distros.
