"Solved" : Ubuntu 14.04 errors occured during execution
I tried to install opennebula on a fresh ubuntu 14.04 install following http://docs.opennebula.org/4.6/design_and_installation/quick_starts/qs_ubuntu_kvm.html.
When doing # apt-get install opennebula-node nfs-common bridge-utils I got the following answer (translation from french) :
Errors occurred during execution
/var/cache/apt/archives/opennebula-sunstone_4.6.2-1_all.deb
/var/cache/apt/archives/ruby-opennebula_4.6.2-1_all.deb
Does somebody have an idea ?
Thanks in advance for your answer.
Oups… The problem is solved.
I was using 4.6 documentation.
Need to use http://docs.opennebula.org/4.10/design_and_installation/quick_starts/qs_ubuntu_kvm.html.
(changes in packages to install.)
Sorry to have disturb.
Could you please try with 4.12 release, the last one?
hi this is sekaran , i have same kind of error like you when i try to install opennebula 4.14 in ubuntu 14.04 kindly help me pls
