Is there a way to delete a Virtual Network address range without completely destroying and rebuilding that Virtual Network?
I erroneously added an address range to a Virtual Network and I would like to remove the address range but can’t figure out how to without completely deleting the entire Virtual Network.
Is there a way to do this without completely rebuilding the Virtual Network?
Hello @cnstarz
Yes it is possible with the cli command:
onevnet rmar <vnetid> <ar_id>
This is also possible via XML-RPC API.
However this is not supported by Sunstone yet.
Regards
