Issue creating input variables in Terraform for Virtual Router templates
Hello I am having issues using user_inputs in terraform for Virtual Routers, the code is as follows
This properly creates the template and prompts for the input value but the value that is injected into the context is always empty. Any help would appreciated.
Terraform Provider: ~> 1.4, also tried ~> 1.3
OpenNebula 6.10.0.1
Create a base terraform provider file
put this main.tf
resource "opennebula_virtual_router_instance_template" "service_vrouter" {
  name        = "Service Virtual Router (With Forwarding)"
  permissions = "642"
  group       = "oneadmin"
  cpu         = "1"
  vcpu        = "1"
  memory      = "512"
  context = {
    network          = "YES"
    host             = "$NAME"
    forward = "$FORWARDING_ROUTE"
  user_inputs = {
    # If this router is going to be used as a pass-through router, you can add a static route
    FORWARDING_ROUTE = "M|text|Test|"
  graphics {
    keymap = "en-us"
    listen = "0.0.0.0"
    type   = "VNC"
  os {
    arch = "x86_64"
    boot = ""
Apply and then create a Virtual Router in the UI.
The creation flow will prompt for the variable but it will be empty once the VM comes up
The creation flow will prompt for the variable and it will be set in the context
