Issue with Database Servers and OpenNebula’s Cloud Management – Any Advice?
Hello everyone,
I’m currently working on optimizing database servers and exploring how to integrate them with OpenNebula’s Cloud Management. While OpenNebula provides robust cloud management features, I’m facing some challenges in effectively leveraging it for managing database servers.
Here are a few areas where I’m seeking advice:
  • Integration Best Practices: What are the best practices for integrating database servers with OpenNebula’s Cloud Management? Are there any common issues or tips for a smooth integration?
  • Performance Optimization: How can I optimize the performance of database servers when using OpenNebula? Any recommendations for balancing resources and improving efficiency?
  • Data Management: What strategies should be used to manage and synchronize data between database servers and OpenNebula’s Cloud Management?
  • Scalability: How can I scale the setup to handle increasing database loads and demands using OpenNebula? What approaches have worked well for others?
If anyone has experience with integrating database servers with OpenNebula’s Cloud Management or has faced similar challenges, your insights and advice would be greatly appreciated.
Thank you in advance for your help!
