Problems with Edge Computing and OpenNebula Edge: Seeking Advice
Hi everyone,
I’m reaching out to seek advice regarding some issues we’re facing with edge computing in conjunction with OpenNebula Edge.
1. Edge Computing Challenges:
We’re dealing with a few problems related to edge computing deployment. Specifically, we’re having trouble with:
  • Performance Variability: The performance of our edge nodes seems to fluctuate significantly. Sometimes, the nodes perform well, but at other times, there are noticeable slowdowns and latency issues.
  • Connectivity Problems: We are experiencing intermittent connectivity issues between edge devices and our central management system. This is causing data synchronization problems and occasional outages.
2. OpenNebula Edge Issues:
In terms of OpenNebula Edge, we’re encountering the following issues:
  • Resource Allocation Difficulties: We’re having trouble with allocating resources effectively. Despite configuring resource quotas, some edge nodes are either over-provisioned or under-provisioned, leading to inefficiencies.
  • Integration Problems: Integrating OpenNebula Edge with our existing monitoring and alerting systems has been problematic. There are frequent discrepancies between the actual state of resources and what OpenNebula reports.
  • Scaling Challenges: As we add more edge devices, scaling the OpenNebula Edge deployment has become cumbersome. We’re seeing performance bottlenecks and management overhead increase significantly.
Has anyone experienced similar issues with OpenNebula Edge or edge computing in general? Any suggestions on best practices for improving performance, resolving resource allocation issues, or better integration strategies would be highly appreciated.
Looking forward to your insights and advice!
