Hi!
I’m getting a kernel panic when i’m trying to boot up a RHEL 6.6 virtual machine:
mount: wrong fs type, bad option, bad superblock on /dev/mapper/vgSys-root_lv, missing codepage or helper program, or other error. In some cases useful info is found in syslog - try dmesg | tail or so
I’ve done the same process for RHEL 6.5 and no problem has arisen, I don’t know if there are any packages i this release than can cause this problem.
Some extra info:
/etc/fstab
/dev/mapper/vgSys-root_lv / ext4 defaults 1 1
/dev/mapper/vgMon-wva_lv /WVA ext4 defaults 1 2
UUID=a5336b69-7438-4876-81f5-ff6bc4f413c2 /boot ext4 defaults 1 2
/dev/mapper/vgMon-ctm_lv /ctmagent ext4 defaults 1 2
/dev/mapper/vgSys-home_lv /home ext4 defaults 1 2
/dev/mapper/vgSys-opt_lv /opt ext4 defaults 1 2
/dev/mapper/vgMon-itm_lv /opt/IBM/ITM ext4 defaults 1 2
/dev/mapper/vgMon-omv_lv /opt/OmniVision ext4 defaults 1 2
/dev/mapper/vgSys-tmp_lv /tmp ext4 defaults 1 2
/dev/mapper/vgMon-bl_lv /usr/local/bl_agent ext4 defaults 1 2
/dev/mapper/vgSys-var_lv /var ext4 defaults 1 2
/dev/mapper/vgSys-varlog_lv /var/log ext4 defaults 1 2
/dev/mapper/vgSys-audit_lv /var/log/audit ext4 defaults 1 2
/dev/mapper/vgSwap-swap_lv swap swap defaults 0 0
tmpfs /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts gid=5,mode=620 0 0
sysfs /sys sysfs defaults 0 0
proc /proc proc defaults 0 0
/dev/vgSoftware/tomcat_lv /opt/tomcat ext4 rw 0 0
/dev/vgSoftware/wily_lv /opt/wily ext4 rw 0 0
/dev/vgSoftware/gestionWAS_lv /opt/gestionWAS ext4 rw 0 0
/dev/vgSoftware/export_lv /export ext4 rw 0 0
/dev/vgSoftware/sds_lv /SDS ext4 rw 0 0
/dev/vgSoftware/zipapps_lv /ZipAplicacionesLogicas ext4 rw 0 0
And template info:
TEMPLATE 145 INFORMATION
USER : oneadmin
GROUP : oneadmin
REGISTER TIME : 11/06 09:03:09
OWNER : um-
GROUP : —
OTHER : —
TEMPLATE CONTENTS
CONTEXT=[
BL_AREA="$BL_AREA",
FILES_DS="$FILE[IMAGE_ID=417]",
INIT_SCRIPTS=“atf-init.sh”,
NETWORK=“YES”,
NTP="$NTP",
SEARCH_DOMAIN="$SEARCH_DOMAIN",
SET_HOSTNAME="$SET_HOSTNAME",
CPU="2"
DISK=[
DEV_PREFIX=“vd”,
DRIVER=“qcow2”,
IMAGE=“JBOSS-JWS-3.3-RHEL66.X64.ATF.PRB.disk1”,
IMAGE_UNAME=“oneadmin” ]
DISK=[
DEV_PREFIX=“vd”,
DRIVER=“qcow2”,
IMAGE=“JBOSS-JWS-3.3-RHEL66.X64.ATF.PRB.disk2”,
DISK=[
DEV_PREFIX=“vd”,
DRIVER=“qcow2”,
IMAGE=“JBOSS-JWS-3.3-RHEL66.X64.ATF.PRB.disk3”,
DISK=[
DEV_PREFIX=“vd”,
DRIVER=“qcow2”,
IMAGE=“JBOSS-JWS-3.3-RHEL66.X64.ATF.PRB.disk4”,
FROM_APP="54f985c1a1d05513be000049"
FROM_APP_NAME="TIBCO-BW-5.11-RHEL-65.X64.ATF.PRB"
GRAPHICS=[
KEYMAP=“es”,
LISTEN=“0.0.0.0”,
TYPE=“VNC” ]
MEMORY="4096"
NIC=[
NETWORK=“ManagementNetwork_VLAN309”,
NETWORK_UNAME=“oneadmin” ]
NIC=[
NETWORK=“ServiceNetwork_VLAN409”,
Can you give a hand, guys? Thanks in advance.
