Limit bandwidth for VM migration
Вот исправленный и улучшенный вариант вашего сообщения:
OpenNebula 6.6.1.1, Ubuntu 22.04
I’m trying to limit the bandwidth used for VM migration between hosts. The storage is local, so during migration the VM consumes the entire available network bandwidth, affecting other VMs.
I added the following line:
exec_and_log "virsh --connect $LIBVIRT_URI migrate-setspeed $DEPLOY_ID --bandwidth 500" \
    "Setspeed to 500M is set!"
to /var/lib/one/remotes/vmm/kvm/migrate and /var/lib/one/remotes/vmm/kvm/migrate_local. This works for live migration.
However, when the migration is not live (i.e., save-restore), the bandwidth limit doesn’t seem to apply.
What should I modify to limit the migration speed for non-live (save-restore) migrations as well?
You can add custom options to the virsh migrate command. You should be able to set --bandwidth in there for live migrations issued by OpenNebula. For save/restore we don’t have a similar option.
Thank you for your answer
