Marketplace driver wont load, opennebula service wont start, system down
We are using community version of 7.0 in a POC environment. Today something went off on the "tokens” and based on what I dug up the serveradmin pwd needed to be updated and I did (updated the sha/hash local file and db).
If you’re curious where I was at before the current issue:
oneadmin@vh207:~$ oneuser show 0 -x
[one.user.info] User couldn’t be authenticated, aborting call.
I couldn’t do anything. Even a simple onevm list would give same issue. Couldn’t reset using oneuser passwd 0 or 1, got same error.
I shut down all the services, adjusted things and then tried to bring things back up and received the followed errors.
… journalctl log …Sep 11 16:24:16 vh207 systemd[1]: Failed to start opennebula.service - OpenNebula Cloud Controller Daemon.
… oned.log…
Thu Sep 11 16:33:02 2025 [Z0][MKP][I]: Starting Marketplace Manager…
Thu Sep 11 16:33:02 2025 [Z0][DrM][E]: Unable to start driver ‘market_exe’: Driver initialization failed, expected INIT SUCCESS message
Thu Sep 11 16:33:02 2025 [Z0][MKP][E]: Driver initialization failed, expected INIT SUCCESS message
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Stopping Virtual Machine Manager
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Stopping Life Cycle Manager
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Life Cycle Manager stopped.
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Stopping Dispatch Manager
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Dispatch Manager stopped.
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Stopping Hook Manager
Thu Sep 11 16:33:02 2025 [Z0][Lis][I]: Stopping Transfer Manager
Thu Sep 11 16:33:03 2025 [Z0][Lis][I]: Virtual Machine Manager stopped.
Thu Sep 11 16:33:03 2025 [Z0][Lis][I]: Hook Manager stopped.
Thu Sep 11 16:33:03 2025 [Z0][Lis][I]: Transfer Manager stopped.
Thu Sep 11 16:33:03 2025 [Z0][ACL][I]: Stopping ACL Manager…
Thu Sep 11 16:33:03 2025 [Z0][Lis][I]: Stopping Authorization Manager
Thu Sep 11 16:33:04 2025 [Z0][Lis][I]: Authorization Manager stopped.
Thu Sep 11 16:33:04 2025 [Z0][ONE][I]: All modules finalized, exiting.
I tried to comment out all the marketplace configs in oned.conf and restart but get the similar error.
Thu Sep 11 16:24:08 2025 [Z0][MKP][I]: Loading Marketplace Manager driver.
Thu Sep 11 16:24:08 2025 [Z0][MKP][I]: Failed to load Marketplace Manager driver.
Thu Sep 11 16:24:08 2025 [Z0][ONE][E]: Could not load driver
Any thoughts on how to resolve?
This is an error with the onadmin user, not the serveradmin user. Basically, the API Calls that the CLI commands issue, are authenticated using the credentials stored at /var/lib/one/.one/one_auth. If these do not match the credentials stored in the database, then you get these auth errors, because it is effectively inputting a wrong password.
When you issue the command oneuser passwd you are also issuing an API Call that needs to be authenticated as well. You have two options
  • update the oneadmin password at /var/lib/one/.one/one_auth to match the oneadmin password in the DB
  • update the password hash in the DB to match the password in the text file
