I am in the process of upgrading opennebula from v5.12.0.3 to v6.2.0.1.
We would like to re-import some vcenter VMs to pick up datastore change.
The first problem we hit was that that VMs could not be deleted . We got the following error even when we ran cleartags in advance:
onevm recover --delete-db 255
[one.vm.recover] Action “delete” is not supported for imported VMs
I followed the instructions here and the VM was removed:
onedb update-body vm --id 255
Remove the tag IMPORTED
However, any VMs which we delete in this manner do not appear in the host wild list hours later.
The VMs are quickly picked up in /var/log/one/vcenter_monitor.log. For example:
VM = [ ID=“-1”, VM_NAME=“VM919-XXXX”, DEPLOY_ID=“vm-44571”, VCENTER_TEMPLATE=“YES”,IMPORT_TEMPLATE=“xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”]
The associated IMPORT_TEMPLATE looks like:
NAME = “VM919-XXXX”
CPU = “4”
vCPU = “4”
MEMORY = “16384”
HYPERVISOR = “vcenter”
CONTEXT = [
NETWORK = “YES”,
SSH_PUBLIC_KEY = “$USER[SSH_PUBLIC_KEY]”
VCENTER_INSTANCE_ID =“a5a4e696-7233-41f8-a9a6-cfb12dd824c3”
VCENTER_CCR_REF =“domain-c7”
DEPLOY_ID =“vm-44571”
IMPORT_STATE =“POWEROFF”
VCENTER_DS_REF = “datastore-59485”
GRAPHICS = [
TYPE =“vnc”,
PORT =“6155”,
LISTEN =“0.0.0.0”
DESCRIPTION = "vCenter Template
imported by OpenNebula from Cluster "
Do you guys have any idea how we can re-import these VMs?
Thanks for your help,
Colm
