Network Question
Hello all,
Question about network configuration.
I’m deploying Opennebula in existing network and server infrastructure (moving to nebula)
And got following case:
Single vlan with multiple independent networks.
VLAN_ID: 123
NET1: 1.2.3.0/24
NET2: 4.5.6.0/24
All routing is done outside nebula, I have bridge virtual networks only.
Question is about IP ranges, as I understand a single virtual interface can have multiple address ranges but context configuration for the gateway, network, etc, is single.
So is it possible to set contextualization variable like network mask, gateway etc per address range? Or I should create as many independent virtual networks as many different address spaces I have?
Of course I understand that my network implementation is not “correct” but I’m working with existing infrastructure and there is no way to change it for now.
Hello! I suppose you could use only the start script in contextualization.
