I’m going to explain my scenario in OpenNebula (updated today to 5.8.5)
- one opennebula machine that acts as server and as kvm node too
- one virtual network (name N_10), with Internet connection (NAT from server), with network address 10.10.10.0 and this configuration:
[oneadmin@system ~]$ onevnet show 0
VIRTUAL NETWORK 0 INFORMATION
USER : oneadmin
GROUP : oneadmin
LOCK : None
CLUSTERS : 0
BRIDGE : br0
VN_MAD : fw
AUTOMATIC VLAN ID : NO
AUTOMATIC OUTER VLAN ID : NO
USED LEASES : 112PERMISSIONS
OWNER : um-
GROUP : —
OTHER : —VIRTUAL NETWORK TEMPLATE
BRIDGE=“br0”
DESCRIPTION=“Internet access”
DNS=“my DNSs”
GATEWAY=“10.10.10.1”
NETWORK_ADDRESS=“10.10.10.0”
NETWORK_MASK=“255.255.255.0”
PHYDEV=“”
SECURITY_GROUPS=“0”
VN_MAD=“fw”ADDRESS RANGE POOL
AR 0
LEASES : 112RANGE FIRST LAST
MAC 02:00:0a:0a:0a:02 02:00:0a:0a:0a:fe
IP 10.10.10.2 10.10.10.254
- a second virtual network (name N_20), without internet connection, with network addres 20.20.20.0 and this configuration:
[oneadmin@system ~]$ onevnet show 1
VIRTUAL NETWORK 1 INFORMATION
USER : oneadmin
GROUP : oneadmin
LOCK : None
CLUSTERS : 0
BRIDGE : br2
VN_MAD : fw
USED LEASES : 177PERMISSIONS
OWNER : um-
GROUP : —
BRIDGE=“br2”
DESCRIPTION=“Middle”
NETWORK_ADDRESS=“20.20.20.0”
NETWORK_MASK=“255.255.254.0”
PHYDEV=“”
SECURITY_GROUPS=“0”
VLAN_ID=“”
AR 0
LEASES : 177RANGE FIRST LAST
MAC 02:00:14:14:14:02 02:00:14:14:15:f5
IP 20.20.20.2 20.20.21.245
server doing NAT with this iptables rule in table NAT:
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -s 10.10.10.0/24 -o br0 -j MASQUERADE
COMMIT -
a linuxbridge br0 connected to physical device eth0
[oneadmin@system ~]$ brctl show
bridge name bridge id STP enabled interfaces
br0 8000.801844ee6b34 no eth0
this bridge br0 has two IP address: a public IP address and 10.10.10.1
another bridge, br2, with no IP address and not connected to any physical device
in Opennebula, both virtual network are created with “Bridged and Security Groups” mode. Neither N_10 nor N_20 have a physical device conneted
Now, I will explain what I have get this morning:
After creating two instances, both of them with two networks interfaces, each of them connected to each virtual network, I have reconfigured inside the instances the IP addresses assigned to them. For example, in both instances I have reconfigured second network interface, changing address from range 20.20.20.X to a “new” range 123.1.1.X. Opennebula scheduler doesn’t know what I have done inside the instance… Now, after restarting networking daemon, I can ping from 123.1.1.2 to 123.1.1.3… but both instances were connected to virtual network 20.20.20.0…
Why?
Thanks.
