Hi, So I have a network setup in OpenNebula:
And when I create a VM it says its assigning an IP within the range:
But the IP is not correct. The VM is getting an IP from my Router via DHCP instead. How can I get open nebula to assign an IP properly?
Do you have opennebula contextualization installed on the VM template image?
BR, Anton
Looking at that now. Kind of confusing though. I put things in the start up script box or what? It doesn’t give good examples on how to actually DO anything.
