Before i get this state, i had MONITORING_ERROR state on second node from “onehost show 1” if i not mistaken(I forgot a little bit). Then i tried to enable the node with “onehost enable 1”. And then i get this init state with some details :
HOST 1 INFORMATION
CLUSTER : default
STATE : MONITORING_INIT
IM_MAD : kvm
VM_MAD : kvm
LAST MONITORING TIME : 01/18 16:58:25
HOST SHARES
RUNNING VMS : 45
MEMORY
TOTAL : 78.6G
TOTAL +/- RESERVED : 157.1G
USED (REAL) : 32.1G
USED (ALLOCATED) : 95G
CPU
TOTAL : 3200
TOTAL +/- RESERVED : 6400
USED (REAL) : 32
USED (ALLOCATED) : 5100
LOCAL SYSTEM DATASTORE #0 CAPACITY
TOTAL: : 360.7G
USED: : 297.9G
FREE: : 44.5G
MONITORING INFORMATION
ARCH="x86_64"
CPUSPEED="1294"
ERROR="Wed Jan 10 23:48:45 2018 : Error monitoring Host opennebulanode2 (1): error: failed to connect to the hypervisor
error: Failed to connect socket to '/var/run/libvirt/libvirt-sock': No such file or directory
ERROR MESSAGE --8<------
Error executing kvm.rb
ERROR MESSAGE ------>8--
ARCH=x86_64
MODELNAME=\"Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz\"
HOSTNAME="opennebulanode2"
HYPERVISOR="kvm"
IM_MAD="kvm"
MODELNAME="Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz"
NETRX="8484511038"
NETTX="21123100924"
RESERVED_CPU="-3200"
RESERVED_MEM="-82371420"
VERSION="5.4.0"
VM_MAD="kvm"
On the opennebula state i got this error :
But, all vms inside the node are running fine. Is this something i should worry and start to fix? I searched for the similar problem on the internet. But, i can’t get enough information and still couldn’t fix the problem. Can you guys help me?
