Not able to start SunStone server after an installation from scratch
We are installing an OpenNebula test environment and I am getting the following error when trying to start the Sunstone server:
[ 2015-07-29 16:25:39.8620 5556/7fd738602700 App/Implementation.cpp:287 ]: Could not spawn process for
application /usr/lib/one/sunstone: An error occured while starting up the preloader.
 Error ID: 651c1b3c
 Error details saved to: /tmp/passenger-error-AKihKL.html
 Message from application: cannot load such file -- routes/appmarket (LoadError)
 /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:53:in `require'
 /usr/lib/one/sunstone/sunstone-server.rb:345:in `block in <top (required)>'
 /usr/lib/one/sunstone/sunstone-server.rb:344:in `each'
 /usr/lib/one/sunstone/sunstone-server.rb:344:in `<top (required)>'
 config.ru:9:in `block in <main>'
 /usr/local/share/gems/gems/rack-1.6.4/lib/rack/builder.rb:55:in `instance_eval'
 /usr/local/share/gems/gems/rack-1.6.4/lib/rack/builder.rb:55:in `initialize'
 config.ru:1:in `new'
 config.ru:1:in `<main>'
 /opt/passenger-5.0.4/helper-scripts/rack-preloader.rb:111:in `eval'
 /opt/passenger-5.0.4/helper-scripts/rack-preloader.rb:111:in `preload_app'
 /opt/passenger-5.0.4/helper-scripts/rack-preloader.rb:157:in `<module:App>'
 /opt/passenger-5.0.4/helper-scripts/rack-preloader.rb:29:in `<module:PhusionPassenger>'
 /opt/passenger-5.0.4/helper-scripts/rack-preloader.rb:28:in `<main>'
Probably, I am missing to install some package/gem or I am just missing something in the configuration. In any case, if you see a clear solution to solve this error, please let me know :smile:
Thanks in advance,
Esteban
Yes you probably missing following command in installation process:
/usr/share/one/install_gems
Above commend installs all necessary ruby modules for OpenNebula. If you have not run the install_gems script, please do.
Hi @kelepirci,
Thanks for answering me :smile:
We have decided to separate the OpenNebula, Sunstone and APP-Market in three different nodes, so I was just installing the appmarket RPMs on the APP-Market node. But it is also necessary to install the appmarket RPMs on the SunStone node in case of having OpenNebula, SunStone and APP-Market installed in different machines, or otherwise, it will not be possible to start sunstone server.
Thanks,
Esteban
hi and sorry for reupload the topic.
there are any solution to have Sunstone and Appmarket in differents nodes? because at now its only possible as @esfreire say… install appmarket in sunstone server and again install appmarket in other node.
SeeU :slight_smile:
No, they have to be in the same node.
