We try to use one gate for standalone vms without one flow, but during execution onegate vm show [VMID] or any other onegate command we catch error: ERROR: Empty or invalid SERVICE_ID.
The question is can we use one gate without oneflow services or it’s necessary? it’s not completely clear from the documentation
You don’t need oneflow if you only wants to get vm information. But remember to start onegate server with the command onegate-server start. Also remember to change the ONEGATE_ENDPOINT in the oned.conf and in the VM you need to add onegate token (it can be done through Sunstone)
I started opennebula-gate.service on my master node, edited the oned.conf and in contex cdrom I have token.txt file, but I can get only onegate vm show if I trying to use vmid as an argument I get an error.
I’m trying to found the way to reboot vm, if it catches kernel panic or BSOD. Is there any opportunity to do that with opennebula ?
Yes, you can only use onegate vm show without ID, because the ID is the ID of the service, not the VM. I think there is no way to do that, you can take a look at VM hooks, but I think they won’t help you in that case.
