I wonder if in ONE 5 is it possible to organize labels in such a way that some of them are sub-labels of other ones.
Thank you very much
Thank you very much
Ok, that worked.
The problem is that the space which remains for the labels in the menu is very small. Is there any way to enlarge it so that I can see all the labels at the same time?
Thank you very much
Regards
