Opennebula HA automated script
Hi ,
I think its use full for newbie’s .
Visit https://github.com/jamesarems/opennebula-distro .
I think it will help ,who suffers to create opennebula as HA cluster .
Used glusterfs as shared storage and OpenVswitch as network backend.
You guys also can edit this script .
Thank You.
Hi friend,
I really appreciate your script. Can you explain a bit more? And post examples?
Well, congratulations, I will try to play with your scripts. But, I am using Debian.
Thank you
Hi Astor_Palmeira,
First of all thanks for your compliment.
Please refer github page , you will get the points . I am just focusing on CentOS distro , thats what i am not trying to writing scripts for debian installation . I will try to write this on future.
1 . Need fresh CentOS 7 system with firewalld and SE Linux disabled .
2 . install git package & set FQDN for both systems and add there IP’s in each /etc/hosts files.
3 . We are using shared storage to get HA function , for that need to mount disk on a location .
Eg : /data
4 . After mount , create a directory inside the mount point . Because we are going to use GlusterFS as share storage and gluster will not support exact mount point to work with .
Eg : /data/disk
These are the initial settings. After that you need to clone git repo . And run install.sh first .
Follow Readme.md file.
Short steps are,
1 . Gluster
2 . Install OpenNebula
3 . Configure OVS (OpenVswitch)
4 . Cluster configuration .
Soon i will create video demo for this.
Thanks
Hi jamesarems,
Thanks for your effort. I’m interested in building a HA-setup using LizardFS. Have checked their documentation also with your readme on github but as being new into this, not clear yet about minimum required number of physical servers.
Q1: Is it possible to build a LizardFS system with total of just two physical servers?
Q2: Is it possible to install opennebula nodes on the same physical nodes of LizardFS or should they be separated?
thanks,
Orhan
Yes , It is possible
I wrote the script only for two machines . If you are familiar with scripting you can edit the source shell file .
Hi ,
I have added some more features in that script .
After installation you will be able to control Opennebula system’s terminal console via Web .
Try it .
Also planning to integrate Icinga into it . This is an Open Source project to help newbie’s to setup there cloud environment with one click . Contributions are accepted .
Thanks
