I have recently deployed Opennebula Front End Server on top of KVM ( on Ubuntu 20.04 ).
I have old EqualLogic Storage which is serving as SAN via iSCSI
When I mount the iSCSI LUN on KVM directly, its working as expected in KVM
but when I mount it on openNebula through libvirt-iscsi it shows as 1MB capacity and does not work.
Any recommendations ? Appreciate your help on this.
regards
Sagar
The behaviour you’re seeing is explained in the documentation:
“As this Datastore is just a container for existing devices, images does not take any size from it. All devices registered will render a size of 0 and the overall devices Datastore will show up with 1MB of available space”
Are you seeing any specific error when you try to deploy a VM using the iSCSI device?
With such a few details it’s hard to know where the error could be. Could you share your DS configuration (i.e onedatastore show -x <ds_id>) and more details on what you’re trying to do exactly?
