OpenVswitch VLAN persistence
VLANs are not persistent across soft reboot. If we reboot the instance via ssh, all VLAN tags on openvswitch are lost.
  • I am using OpenNebula 5.2 on production and 5.4 on our staging environments. We use a mix of mostly xen along with KVM deployments
  • OpenVSwitch 2.3.1
  • Login to any of the VM (which has vlan tagged interfaces) via ssh and do a reboot manually on cmd.
  • The VM would shutdown and come up on its own normally but all the VLAN info would be lost
  • We have to poweroff/poweron the VM again from sunstone to apply the VLAN tags correctly again
  • VLANs should be persstent across reboots.
  • The deployment.cfg file should have he VLAN tag present as part of the VIF
We wrote a script. The script queries the opennebula API and gets the VLAN and applies the same
