Possible to run multiple fronted HA RAFT leader/follower hook scripts?
I have successfully deployed a HA frontend cluster and VIP handoff works correctly using the RAFT_LEADER_HOOK and RAFT_FOLLOWER_HOOK sections in the frontend server /etc/one/oned.conf. But now I am interested in running some other frontend post-election scripts as hooks.
Is it possible to add multiple other scripts to the /var/lib/one/remotes/hooks/raft directory on frontend servers and call them via multiple RAFT_LEADER and RAFT_FOLLOWER hook entries in oned.conf? Or will I just have to modify the default raft/vip.sh script and track changes to that file between ONE version upgrades?
Thanks,
Dave
HI Dave,
how did you finaly manage it?
Cheers,
Thomas
Hi @tku,
You know my original thought was to use the raft script to move the vm provisioning logs between frontends as the VIP moves, but I never really followed up with it. I’ll drop it in my queue this week, see if I can get it to work, and post my results here.
-Dave
Hi Dave,
thanks!
Thomas
Hi Thomas and Dave,
I had to add a default route to the network interface managed by the vip.sh script. I simply created a new script in the raft directory named vip-route.sh and replaced vip.sh in the RAFT_LEADER_HOOK parameter in /etc/one/oned.conf:
RAFT_LEADER_HOOK = [
     COMMAND = "raft/vip-route.sh",
     ARGUMENTS = "leader ens15f0 [public IP]/24"
Here is the content of the raft/vip-route.sh script:
#!/bin/bash -e
# Execute the original vip.sh script
bash remotes/hooks/raft/vip.sh $1 $2 $3
sudo ip route add default via [gateway] table WAN
exit 0
Don’t forget to use sudo in your custom script. You can see which command the oneadmin user can execute using sudo in /etc/sudoers.d/opennebula.
Good luck,
Guillaume
Hi Thomas and Guillaume,
I tried looking through the raftmanager code but didn’t see how I could add another RAFT_LEADER_HOOK and RAFT_FOLLOWER_HOOK vector entry without modifying more than I wanted to, so I took a similar route as Guillaume and ended up just modifying the default vip.sh script to do more actions when passed the leader and follower actions. It’s kind of annoying because I’ll have to make sure to merge and track my changes on the vip.sh script through upgrades, but not an impossible task.
I did end up successfully getting the exiting leader node to transfer over the VM provisioning logs to the new leader node by updating the leader action to modify SSH on the leader node to listen on the VIP address, and then modifying the follower action to disable SSH for the VIP address and copy over just the VM provisioning logs to the new leader node that claimed the VIP.
Here’s the updated /var/lib/one/remotes/hooks/raft/vip/.sh:
ACTION="$1"
INTERFACE="$2"
IFADDR="$3"
IP="${IFADDR%%/*}"
REGIP="${IP//./\\.}"
if [ -z "$INTERFACE" ]; then
    echo "Missing interface." >&2
    exit 1
fi
if [ -z "$IFADDR" ]; then
    echo "Missing IP." >&2
    exit 1
fi
if which systemctl &>/dev/null && [ -d /etc/systemd ]; then
    IS_SYSTEMD=yes
else
    IS_SYSTEMD=no
fi
case $ACTION in
leader)
    sudo ip address add $IFADDR dev $INTERFACE
    for i in $(seq 5); do
        sudo arping -c 1 -U -I $INTERFACE ${IP}
        sleep 1
        sudo arping -c 1 -A -I $INTERFACE ${IP}
        sleep 1
    done
    # check if listenaddress VIP is commented out
    if sudo -n egrep -q "^#+ *ListenAddress +${IP}" /etc/ssh/sshd_config
    then
      # if it is then uncomment it
      sudo -n sed -i -E "/^#+ *ListenAddress +${REGIP}/s/^#+ *//" /etc/ssh/sshd_config
    else
      # if its not present then append it to the file
      echo "ListenAddress $IP" | sudo -n tee -a /etc/ssh/sshd_config
    fi
    if [ "${IS_SYSTEMD}" = 'yes' ]
    then
      sudo -n systemctl restart sshd >/dev/null 2>&1
    else
      sudo -n service sshd restart >/dev/null 2>&1
    fi
    if [ "${IS_SYSTEMD}" = 'yes' ]; then
        if systemctl is-enabled opennebula-flow >/dev/null 2>&1; then
            sudo -n systemctl start opennebula-flow
        fi
        if systemctl is-enabled opennebula-gate >/dev/null 2>&1; then
            sudo -n systemctl start opennebula-gate
        fi
    else
        if [ -e /usr/lib/one/oneflow/oneflow-server.rb ]; then
            sudo -n service opennebula-flow start
        fi
        if [ -e /usr/lib/one/onegate/onegate-server.rb ]; then
            sudo -n service opennebula-gate start
        fi
    fi
follower)
    if sudo ip address show dev $INTERFACE | grep -qi " ${IP}/"; then
        sudo ip address del $IFADDR dev $INTERFACE
    fi
    #if VIP listenaddress is in sshd_config comment it out
    sudo -n sed -i -E "s/^ *ListenAddress +${REGIP}/#ListenAddress ${REGIP}/" /etc/ssh/sshd_config
    then
      sudo -n systemctl restart sshd >>/dev/null 2>&1
    else
    fi
        if systemctl is-enabled opennebula-flow >/dev/null 2>&1 ||
           systemctl is-active  opennebula-flow >/dev/null 2>&1;
        then
            sudo -n systemctl stop opennebula-flow
        fi
        if systemctl is-enabled opennebula-gate >/dev/null 2>&1 ||
           systemctl is-active  opennebula-gate >/dev/null 2>&1;
        then
            sudo -n systemctl stop opennebula-gate
        fi
    else
            sudo -n service opennebula-flow stop
        fi
            sudo -n service opennebula-gate stop
        fi
    fi
    # copy over only VM provisioning logfiles (eg 125.log)
    sleep 10
    find /var/log/one -type f -regextype posix-egrep -regex ".*/[[:digit:]]+\.log" |
    cut -d / -f 5 |
    rsync -az --include-from=- --exclude='*' /var/log/one/ oneadmin@"${IP}":/var/log/one >>/dev/null 2>&1
    echo "Unknown action '$ACTION'" >&2
    exit 1
esac
exit 0
And here’s just the updated content of /etc/sudoers.d/opennebula:
Cmnd_Alias ONE_HA = /usr/bin/systemctl start opennebula-flow, /usr/bin/systemctl stop opennebula-flow, /usr/bin/systemctl start opennebula-gate, /usr/bin/systemctl stop opennebula-gate, /usr/sbin/service opennebula-flow start, /usr/sbin/service opennebula-flow stop, /usr/sbin/service opennebula-gate start, /usr/sbin/service opennebula-gate stop, /usr/bin/sed, /usr/bin/egrep, /usr/bin/tee, /usr/bin/systemctl restart sshd
oneadmin ALL=(ALL) NOPASSWD: ONE_MISC, ONE_NET, ONE_LVM, ONE_ISCSI, ONE_OVS, ONE_XEN, ONE_CEPH, ONE_MARKET, ONE_HA
Look here if you’re interested in locking down the additional commands in sudoers to only allow running specific explicit commands with specific parameters.
If you need to troubleshoot the log copying regex just temporarily update the rsync command in vip.sh on all controller nodes with a -vv flag and change >/dev/null to a writable temp file like >>/tmp/rafttest and forcefully transition leader nodes.
Thanks,
Dave
