I created more than one host in opennebula 5.0.2 but the status of host is going to error state. can’t we create more than one host in opennebula 5.0.2?
Hi!
you should give more information about what is causing your error (what hypervisor are you using, what OS, what have you tried…). Most of the times you should check /var/log/one/oned.log and look for any error related to the host. In this situation you may also use the command: onehost show ID , where ID is your host identifier in OpenNebula…maybe there’s some info about the error.
Answering your question, sure, you can create more than one host in OpenNebula 5.0.2.
Cheers!
hi!
i’m using Kvm hypervisor and cent os
checked /var/log/one/oned.log file
Tue Nov 22 00:15:24 2016 [Z0][ReM][D]: Req:6928 UID:0 HostInfo invoked , 2
Tue Nov 22 00:15:24 2016 [Z0][ReM][E]: Req:6928 UID:0 HostInfo result FAILURE [HostInfo] Error getting host [2].
HOST 28 INFORMATION
CLUSTER : default
STATE : ERROR
IM_MAD : kvm
VM_MAD : kvm
LAST MONITORING TIME : 11/22 00:20:05
HOST SHARES
TOTAL MEM : 0K
USED MEM (REAL) : 0K
USED MEM (ALLOCATED) : 0K
TOTAL CPU : 0
USED CPU (REAL) : 0
USED CPU (ALLOCATED) : 0
RUNNING VMS : 0
MONITORING INFORMATION
ERROR=“Tue Nov 22 00:20:05 2016 : Error monitoring Host test_host (28): -”
IM_MAD=“kvm”
RESERVED_CPU=""
RESERVED_MEM=""
VM_MAD=“kvm”
WILD VIRTUAL MACHINES
NAME IMPORT_ID CPU MEMORY
VIRTUAL MACHINES
