Hi all
I think that this is an issue related with Spice HTML5 client, if you open a text window (using a minimal tty linux for example) everything is working, the spice screen is updated, but if you open a spice screen that includes graphics (ubuntu or arch vms) the spice screen is not updated at all, and you get these errors over and over again:
FIXME: Unable to interpret bitmap of format: 2
2: Unknown message type 304!
2: Unknown message type 107!
if you connect directly to the hyp using a client like spicec --host hyp101 --port 6201 everything work fine… anyone has the same issue? I was googling a bit at it seems a html5 client issue but just to confirm that sunstone is also affected. I’m using firefox 40.0.3.
Cheers and thanks!
Alvaro
