Hello!
I am using Opennebula in Version 4.14.0 with kvm in Centos 7. I’m trying configure host like local storage using lvm. For such , i set up a datastore using block lvm. But when i create a vm with image stored in lvm datastore , get following error in status host:
Tue Dec 8 11:13:19 2015 : Error monitoring Host 10.0.0.2 (2): Error executing poll.sh
Deleting this vm with image stored in lvm datastore, host status back to “on”.
Here the following error log in /var/log/one/oned.log on frond-end machine:
Command execution fail: 'if [ -x "/var/tmp/one/im/run_probes" ]; then /var/tmp/one/im/run_probes kvm /var/lib/one//datastores 4124 20 2 10.0.0.2; else exit 42; fi'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: Warning: Permanently added '10.0.0.2' (ECDSA) to the list of known hosts.
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: ../../vmm/kvm/poll:368:in `block in get_disk_usage': undefined method `match' for nil:NilClass (NoMethodError)
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from /usr/share/ruby/rexml/element.rb:905:in `block in each'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from /usr/share/ruby/rexml/xpath.rb:67:in `each'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from /usr/share/ruby/rexml/element.rb:905:in `each'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:329:in `get_disk_usage'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:145:in `block in get_all_vm_info'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:129:in `each'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:129:in `get_all_vm_info'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:856:in `print_all_vm_template'
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: from ../../vmm/kvm/poll:908:in `<main>'
Tue Dec 8 11:22:46 2015 [Z0][InM][E]: Error executing poll.sh
Tue Dec 8 11:22:46 2015 [Z0][InM][E]: Error executing collectd-client_control.sh
Tue Dec 8 11:22:46 2015 [Z0][InM][I]: ExitCode: 1
