Problem with use of node.js and API XML RPC
I’ve got some trouble with using the API XML RPC with node.js.
I would like to know if it’s possible to use this API with other language then Ruby, PyOne, java.
And could i get a example of this use with node.js back-end server.
Thank a lot,
See you soon.
OpenNebula have bindings for Ruby, Python, Java and Golang but not for node.js. Here (System Interfaces — OpenNebula 5.8.5 documentation) you can find more information about the supported APIs and some examples.
If you want to use node.js with OpenNebula you have to find a node.js XMLRPC library and make the calls by yourself. The XMLRPC calls format is available here: XML-RPC API — OpenNebula 5.8.5 documentation
Ok, you just mean that i’ve bindings with those language.
Well, in fact, i could use python with django to make it work well with a web app ?
It might be hard to use node with XML RPC then. I will think a bit about it.
Thanks for your answer.
If you need to works with node.js you can take a look at this repo https://github.com/OpenNebula/addon-nodejs but it is not officially supported.
About using the python API with django I’ve never do something similar but it should works.
But do you think, in a close futur, we will be able to get official binding for nodejs supported for opennebula ? I don’t know if you are from the team opennebula.
Do you have some idea to help me to build a web app base on the API XML-RPC for Opennebula. Such as good language and framework ?
Yes, I’m from the OpenNebula team but I don’t know if a node.js API will be added soon.
Regarding to make a web app base on our APIs you can take as example our web interface, Sunstone, which use ruby.
Ok, thank a lot ! I will try my best then.
