Prune Promethues data
I am doing some house keeping and notice that my promethues is taking quite a bit of disk space.
4.1G /var/lib/prometheus/data
v7.01
whats the safest way to prune the data
Hello @hoosain,
This is probably more for Prometheus than for OpenNebula :wink:
Prometheus doesn’t have a built-in “prune now” button for existing historical data… it manages old data automatically based on your retention settings.
From what I could investigate, by default Prometheus keep a 15 days track of data.
You can set a shorter retention policy, by configuring this on Prometheus, or you can manually delete the data (which is not recommendable).
So basically, the suggestion is to update your retention settings, and then restart prometheus to check if the old data has been cleaned up.
Regards,
