On a bare metal system you can set the bios to boot from the disk, is there is not OS on the disk, it will boot from the nic/pxe
I can’t seem to get opennebula to do that. Which means I have to watch the install. I then have to wait for it to begin to
reboot and then power off - hard, go into conf and change the boot device to disk. This also means it is very difficult to install multiple vm’s at one time.
Opennebula 5.2.1
Cobbler 2.8.1
set boot order boot, nic or nic,boot
If set to boot to disk first and there is no OS, it will find no boot device
If nic is set first, it will boot from the network and when the install it will reboot and again boot via network, redoing the install
Expected results:'
If no OS on the disk boot from the network (pxe), if OS found on disk, boot from disk
