Hi all, I was setup FS Qcow2 datastore using gfs2 filesystem. This filesystem I mounted to /var/lib/one/datastores/108 on every compute node by pacemaker.
In /var/lib/one is mounted NFS from Opennebula frontend.
When I use persistent image, all is ok. Problem is with non-persistent images. They are created in system DS id 0. System DS has just 20GB, so after while I cant deploy more VMs with this error:
Cannot schedule VM, there is no suitable system ds.
So I look into qcow ds config and see that CLONE_TARGET = SYSTEM which cannot be changed in sunstone.
I open oned.conf and edited Qcow2 TM to set CLONE_TARGET = SELF, them update din frontend also and force synced hosts.
After this, problem about no suitable ds dissapeared, so I can deploy new VMs. BUT…
non-persistant images are still creating in system ds. Any ideas?
[oneadmin@engine1 ~]$ onedatastore list
ID NAME SIZE AVAIL CLUSTER IMAGES TYPE DS TM STAT
0 system 19G 36% feldhost 0 sys - shared on
1 default 19G 36% feldhost 4 img fs shared on
2 files 19G 36% feldhost 2 fil fs ssh on
104 images 2.4T 29% feldhost 29 img lvm lvm on
106 raid10 2.7T 63% feldhost 0 img lvm lvm on
108 gfs 1023.9G 100% feldhost 2 img fs qcow2 on
[oneadmin@engine1 ~]$ onedatastore show 108
DATASTORE 108 INFORMATION
USER : feldsam
GROUP : oneadmin
CLUSTER : feldhost
TYPE : IMAGE
DS_MAD : fs
TM_MAD : qcow2
BASE PATH : /var/lib/one/datastores/108
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 1023.9G
FREE: : 1020.6G
USED: : 3.3G
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
BASE_PATH="/var/lib/one/datastores/"
BRIDGE_LIST="node1 node2 node3"
CLONE_TARGET="SELF"
DISK_TYPE="FILE"
DS_MAD="fs"
LN_TARGET="NONE"
STAGING_DIR="/var/lib/one/datastores/108/tmp"
TM_MAD="qcow2"
TYPE="IMAGE_DS"
[root@node1 ~]# df -h
192.168.2.50:/var/lib/one 19G 13G 6.9G 64% /var/lib/one
/dev/mapper/vg--raid10-gfsTest 1.0T 3.4G 1021G 1% /var/lib/one/datastores/108
Thank you.
