Question about MySQL database maintenance
Hi all
We were running OpenNebula for a while in our cluster and at this moment we want to cleanup the current mariadb database. We saw from the documentation:
https://docs.opennebula.io/5.10/deployment/opennebula_installation/mysql_setup.html#mysql-database-maintenance
how to do that in 5.10.x, we are running the same version in our server at this moment.
Unfortunately we get an error running these commands (we have stopped opennebula service first):
MariaDB [opennebula]> alter table vm_pool drop index ftidx;
ERROR 1091 (42000): Can't DROP 'ftidx'; check that column/key exists
maybe the documentation is outdated and the index name is wrong? should we use a different command to cleanup our database?
Thanks in advance!
Álvaro
Hello @alvaro_simongarcia,
Note that OpenNebula only creates the index if the current version of the MariaDB servers supports it. MariaDB >= 10.0.5 is required.
Can you confirm that your current version is lower than 10.0.5?
Hi @cgonzalez
Thanks a lot for the reply. Yes indeed, I’m testing this in a very old version with CentOS7. mariadb-server-5.5.64-1.el7 so it does not support this feature.
Thanks for the tip!
Cheers
Álvaro
