madko
(Edouard (Madko))
#1
In oned.conf there is a bloc to configure the automatic VLAN id (we use OpenVswitch).
VLAN_IDS = [
START = "2000",,
RESERVED = "0, 1, 4095"
Is there a way to add and END ? We try this:
VLAN_IDS = [
START = "2000",
END = "3499",
No error, but is it correct ?
ps: Can’t find this in the documentation.
ruben
(Rubén S. Montero)
#2
Limit is only set for 802.1Qx + ovswitch, it is limited to 4095 (by oned,
for these drivers only)
madko
(Edouard (Madko))
#3
How can I tell oned to only use VLANs from 2000 to 3499 ? (3499 or any other end of range)
ruben
(Rubén S. Montero)
#4
Not, supported right now, you need to put all the numbers in oned.conf. We
need to add ranges (eg. reserved 3500-4000)
madko
(Edouard (Madko))
#5
Thanks Ruben. Any ticket to follow the implementation of this feature ?
ruben
(Rubén S. Montero)
#6
madko
(Edouard (Madko))
#7
thanks again Ruben. That’s perfect
