Reg sunstone - auth error
Hi All,
         I have configured openenbula 4.12(suntone+frontend on one machine) &  sunstone on another machine.
when i try to login sunstone, i got the following error…
Oned.log …
Fri May 8 19:32:03 2015 [Z0][AuM][D]: Message received: LOG I 34 Command execution fail: /var/lib/one/remotes/auth/server_cipher/authenticate serveradmin 11edcfe01f42ac0baf6e27da02b9a7c76ad$
Fri May 8 19:32:03 2015 [Z0][AuM][I]: Command execution fail: /var/lib/one/remotes/auth/server_cipher/authenticate serveradmin 11edcfe01f42ac0baf6e27da02b9a7c76ad43c74 ****
Fri May 8 19:32:03 2015 [Z0][AuM][D]: Message received: LOG E 34 bad decrypt
Fri May 8 19:32:03 2015 [Z0][AuM][I]: bad decrypt
Fri May 8 19:32:03 2015 [Z0][AuM][D]: Message received: LOG I 34 ExitCode: 255
Fri May 8 19:32:03 2015 [Z0][AuM][I]: ExitCode: 255
Fri May 8 19:32:03 2015 [Z0][AuM][D]: Message received: AUTHENTICATE FAILURE 34 bad decrypt
Fri May 8 19:32:03 2015 [Z0][AuM][E]: Auth Error: bad decrypt
Endlog…
(i) i have added credential of working sunstone @ /var/lib/one/.one/sunstone_auth
(ii) permission also set to "oneadmin’ for the file “sunstone_auth”,
Kindly help me in this regards,
It seems that the password in sunstone_auth does not match the one in the database. Check that the output of this command matches the password field from oneuser show serveradmin:
$ echo -n <password in sunstone_auth> | openssl sha1
