Hello all:
I got OpenNebula 4.12 on Centos 4.12. I can get to the web ui on the local host only.
Here is /etc/open/sunstone-server.conf:
Server Configuration
Directory to store temp files when uploading images
:tmpdir: /var/tmp
OpenNebula sever contact information
:one_xmlrpc: http://localhost:2633/RPC2
:host: 0.0.0.0
:port: 9869
Place where to store sessions, this value can be memory or memcache
Use memcache when starting multiple server processes, for example,
with passenger
NOTE. memcache needs a separate memcached server to be configured. Refer
to memcached documentation to configure the server.
:sessions: memory
Memcache configuration
:memcache_host: localhost
:memcache_port: 11211
:memcache_namespace: opennebula.sunstone
Log
Log debug level
0 = ERROR, 1 = WARNING, 2 = INFO, 3 = DEBUG
:debug_level: 3
Auth
Authentication driver for incomming requests
sunstone, for OpenNebula’s user-password scheme
x509, for x509 certificates based authentication
opennebula, the authentication will be done by the opennebula core using the
driver defined for the user
:auth: opennebula
Authentication driver to communicate with OpenNebula core
cipher, for symmetric cipher encryption of tokens
x509, for x509 certificate encryption of tokens
:core_auth: cipher
For LDAP auth. Encode credentials sent to OpenNebula. Turns espaces into %20.
This only works with “opennebula” auth.
#:encode_user_password: true
UI Settings
:vnc_proxy_
port: port where the vnc proxy will listen
support_wss: no | yes | only. For yes and only, provide path to
cert and key. “yes” means both ws and wss connections will be
supported.
vnc_proxy_cert: Certificate to encrypt wss connections.
vnc_proxy_key: Key for wss connections. Only necessary if not included in cert.
vnc_proxy_ipv6: Enable ipv6 support for novnc-server
:vnc_proxy_port: 29876
:vnc_proxy_support_wss: no
:vnc_proxy_cert:
:vnc_proxy_key:
:vnc_proxy_ipv6: false
Default language setting
:lang: en_US
Default table order
:table_order: desc
Marketplace
Marketplace username and password
If no credentials are provided, an anonymous client will be used
#:marketplace_username:
#:marketplace_password:
OneFlow
OneFlow endpoint
:oneflow_server: http://localhost:2474/
Default instance types for the cloud view
These types are presented in the cloud view to customize VM Templates. Each
type is defined by:
name: the name of the type
cpu: capacity allocated to the VM for scheduling purposes
vcpu: number of cores
memory: in MB for the VM
description: to help the user pick one, it may include purpose or price.
:instance_types:
- :name: small-x1
:cpu: 1
:vcpu: 1
:memory: 128
:description: Very small instance for testing purposes
- :name: small-x2
:cpu: 2
:vcpu: 2
:memory: 512
:description: Small instance for testing multi-core applications
- :name: medium-x2
:cpu: 2
:vcpu: 2
:memory: 1024
:description: General purpose instance for low-load servers
- :name: medium-x4
:cpu: 4
:vcpu: 4
:memory: 2048
:description: General purpose instance for medium-load servers
- :name: large-x4
:cpu: 4
:vcpu: 4
:memory: 4096
:description: General purpose instance for servers
- :name: large-x8
:cpu: 8
:vcpu: 8
:memory: 8192
:description: General purpose instance for high-load servers
Routes
Array of files containing ruby code to extend the default sunstone-server
routes. These files must be placed inside the custom_routes directory
in the sunstone root dir (/usr/lib/one/sunstone/routes)
Example:
$ ls /usr/lib/one/sunstone/routes
custom.rb other.rb
$ cat /usr/lib/one/sunstone/routes/example.rb
get ‘/custom’ do
body “It works”
end
#:routes:
- custom
- other
:routes:
- oneflow
- vcenter
- support
