recently I ran into various problems related to user quotas. Usually when the quota is exceeded, neither user nor oneadmin receives a feedback indicating which quota is exceeded and by whom, only scheduling a VM fails:
after running “
onehost flush” some VMs on a given host are marked for migration, but migration fails afterwards, because the owner of these VMs is over his own quota. I think rescheduling a running VM which is over a particular quota should not fail, because by rescheduling the situation with resource usage does not change. The particular problem I ran into was caused by a VM created by oneadmin and later given to an ordinary user (onevm chown). Even at that time no warning that the target user is over his quota was given. -
when an user has RAM quota 8 GB, it is not possible to create a single VM with 8 GB RAM - the VM gets created, but it is in PENDING state indefinitely, and only “
onevm resize VMID --memory=6000” helps (--memory=7000does not), Why such a big difference?oneuser show someuser
USER 1234 INFORMATION
RESOURCE USAGE & QUOTASNUMBER OF VMS MEMORY CPU SYSTEM_DISK_SIZE 1 / 8 8G / 8G 0.20 / 1.50 2G / 8Gonevm show 1875
VIRTUAL MACHINE 1875 INFORMATION
STATE : PENDING
LCM_STATE : LCM_INIT
RESCHED : No
START TIME : 05/22 09:31:41
SCHED_MESSAGE=“Tue May 22 10:17:18 2018 : Cannot dispatch VM to any Host. Possible reasons: Not enough capacity in Host or System DS, or dispatch limit reached”VIRTUAL MACHINE TEMPLATE
MEMORY=“8192”
I think the VM in question should not be created at all, if ONe thinks it is over quota. And after it is created, its migration should work regardless of the quota.
Thanks!
-Yenya
