I have a question that I hope is simple to answer, first of all, my network typology.
2 Nodes, managed by a single front end.
(172.16.1.32) Physical PC -----G0/1/13- Network Switch -G0/1/0 -------eth1- Node1(KVM) -------Virtual Server(172.16.1.44)
I also have another remote site with a similar configuration.
(172.16.33.32) Physical PC -----G1/7- Network Switch -G1/10 -------eth3- Node2(KVM) -------Virtual Server(172.16.33.44)
We are stuck creating a physical to Virtual LAN mapping (Bridge Interface). I need to map the port on Node 1 (eth1) to a virtual network so that I can assign the virtual server to this subnet.
How do I go about building the virtual network inside OpenNebula? How do I assign the virtual network bridge interface to s single port? I do not need the virtual network to be built on host2, only host1.
Can anyone point us in the right direction.
Thank You,
