I have created my own storage drivers for both ZFS and LizardFS file systems. My drivers store the disk images as a group via datasets in ZFS and directory in LizardFS. My drivers were written for older ONE before snapshots were supported. I would like to update the drivers to support snapshots.
Using ONE 5.6, I did a bit of experimenting to see what facilities are called when creating a snapshot. When I try to snap a VM, I see the script /var/tmp/one/vmm/kvm/snapshot_create is called. However, the script just returns error “unsupported configuration: internal snapshot for disk hda unsupported for storage type raw” I’m guessing it expects qcow type images for snapshots. However, technically I can still perform snaps for raw images because the filesystems I use support creating a snapshot of anything. For VM’s that have multiple disk images, I get a consistent snapshot by snapping the entire dataset or directory.
It seems like there should be a way for the KVM (or any other hypervisor driver) to pass the snap request down to the storage driver(s).
How best should I go about implementing this functionality? Should I modify the kvm vmm driver? I would prefer not to do that since it would make future ONE upgrades require merging my changes. Is there some other way that I’m not aware of?
Thanks in advance,
gary
