[SOLVED] Error context in templaate
[one.template.instantiate] Error allocating a new virtual machine template. Error parsing: $FILE[IMAGE=init.sh, IMAGE_UNAME=oneadmin]. syntax error, unexpected EOA, expecting COMMA or CBRACKET at line 1, columns 17:18
At v5.4 can`t create VM from template with contextualisation.
The same file at 5.2 with context work normal.
Difference from 5.2 and 5.4
03
Hello @GabrielDias,
This issue is the same that https://dev.opennebula.org/issues/5290.
In 5.4.1 is resolved.
Regards,
Abel.
Thank you.
