with OpenNebula 5.8 we get a reduced version of one.vmpool.info using the xmlrpc-api.
Unfortunately I’m relying on certain attributes in the USER_TEMPLATE for some functionality which now stopped working properly due to the update.
Is there a way to (partially) reactivate the previous behavior that delivered the complete USER_TEMPLATE? Or is it maybe possible to define which attributes shall be delivered?
The only way I see to get the respective USER_TEMPLATE attributes would be to query the vmpool and afterwards query every single vm that was retrieved by the filtered vmpool-query result. This works, but is very horrible from a performance point of view.
Best regards,
Daniel
