While uploading an ISO file to a fresh install Opennebula 5.12 On Ubuntu 18.04, we see that the upload gets stuck and sunstone crashes. If we reload the webpage we are prompted to re-enter the username and password.
This issue is reproducible and happens on all the hosts. We are not using any proxy, just the Host LAN IP on port 9869
We have 6.8 GB available of space in /var/tmp while the ISO is 4.6 GB.
Perhaps there is a double copy that requires 2X free space for iso on the /var/tmp directory?
Sep 11 16:52:31 PS-Node3 ruby[1184015]: == Sinatra has ended his set (crowd applauds)
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /usr/lib/ruby/2.5.0/delegate.rb:349:inwrite': closed stream (IOError) Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /usr/lib/ruby/2.5.0/delegate.rb:349:in<<’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /usr/lib/ruby/2.5.0/delegate.rb:349:inblock in delegating_block' Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/request.rb:79:inparse’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/connection.rb:39:inreceive_data' Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:inrun_machine’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:inrun' Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/backends/base.rb:73:instart’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/server.rb:162:instart' Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/handler/thin.rb:22:inrun’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/sinatra-2.0.8.1/lib/sinatra/base.rb:1526:instart_server' Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /var/lib/gems/2.5.0/gems/sinatra-2.0.8.1/lib/sinatra/base.rb:1460:inrun!’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: from /usr/lib/one/sunstone/sunstone-server.rb:1047:in<main>' Sep 11 16:52:32 PS-Node3 ruby[1184015]: Invalid request: Invalid HTTP format, parsing fails. Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/request.rb:84:inexecute’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/request.rb:84:inparse' Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/connection.rb:39:inreceive_data’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:inrun_machine' Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:inrun’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/backends/base.rb:73:instart' Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/thin-1.7.2/lib/thin/server.rb:162:instart’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/handler/thin.rb:22:inrun' Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/sinatra-2.0.8.1/lib/sinatra/base.rb:1526:instart_server’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: /var/lib/gems/2.5.0/gems/sinatra-2.0.8.1/lib/sinatra/base.rb:1460:inrun!' Sep 11 16:52:32 PS-Node3 ruby[1184015]: /usr/lib/one/sunstone/sunstone-server.rb:1047:in’
Sep 11 16:52:32 PS-Node3 ruby[1184015]: Stopping …
Sep 11 16:52:32 PS-Node3 systemd[1]: opennebula-sunstone.service: Main process exited, code=exited, status=1/FAILURE
Sep 11 16:52:32 PS-Node3 systemd[1]: opennebula-sunstone.service: Failed with result ‘exit-code’.
Sep 11 16:52:37 PS-Node3 systemd[1]: opennebula-sunstone.service: Service hold-off time over, scheduling restart.
Sep 11 16:52:37 PS-Node3 systemd[1]: opennebula-sunstone.service: Scheduled restart job, restart counter is at 2.
Sep 11 16:52:37 PS-Node3 systemd[1]: Stopped OpenNebula Web UI Server.
Sep 11 16:52:37 PS-Node3 systemd[1]: Starting OpenNebula Web UI Server…
Sep 11 16:52:37 PS-Node3 systemd[1]: Started OpenNebula Web UI Server.
Opennebula 5.12
Upload a new ISO, we are using a 4.6GB Windows ISO but it happens on any ISO
Upload gets stuck and Sunstone crashes
Upload should complete without error and Sunstone shouldn’t crash
