turboleta
(turboleta)
April 25, 2021, 4:48pm
1
I installed opennebula 5.12.0.3, but I’m not able to upload an image to the storage, I click in Storage> Images, but the uploading never finish, sometimes it stop at 4.3% other at 10.1%… it depends
Could you help me? Maybe I did something in installation
Regards
ahuertas
(Alejandro Huertas)
April 26, 2021, 7:19am
2
Hello @turboleta ,
Check that you have enough space on /var/tmp.
Best,
Álex.
turboleta
(turboleta)
April 26, 2021, 8:55am
3
Yes, there are 12G free, I’m trying to upload an iso of 1Gb…
turboleta
(turboleta)
April 27, 2021, 12:41pm
4
Do you know what logs should I look?
ahuertas
(Alejandro Huertas)
April 28, 2021, 10:09am
5
Hello @turboleta ,
You can take a look at /var/log/one/sunstone.log and /var/log/one/sunstone.error (if it exists)
Also, it would be nice that you try to create the image using the CLI to see if you have the same trouble, take a look at oneimage create command.
Best,
Álex.
In sunstone.log I got this while I’m uploading the iso:
It repeats until I click in another button, when I do, the login web appear again
The sunstone.error doesn’t exists
