Hi all,
Our datastore configuration is as follows:
File System Datastore: NFS Shared folder mounted on /filesystem_datastore
System Datastore: GlusterFS volume mounted on /system_datastore
The problem is when creating the system datastore thru Sunstone or CLI, we are unnable to create a DS with
TYPE=“SYSTEM_DS”.
Our VM are created as qcow2 in order to generate delta files on the system datastore. How is it possible to create a system datastore and access it using libgfapi?
Thank you in advance,
