Hi All!
When I create a VM, there is a parameter TARGET in the disk templates do select the device qhere the given disk should be available. However it does not work for me. I select targets (hda, hdb, hdc), but the disks are available elsewhere (/dev.sr0, sr1, sr2).
Am I dowing anything wrong? VM template follows.
Regards,
Marcus Rocha
User template
HOT_RESIZE = [
CPU_HOT_ADD_ENABLED = “NO”,
MEMORY_HOT_ADD_ENABLED = “NO” ]
HYPERVISOR = “kvm”
INPUTS_ORDER = “”
MEMORY_UNIT_COST = “MB”
Template
AUTOMATIC_DS_REQUIREMENTS = “(“CLUSTERS/ID” @> 109)”
AUTOMATIC_NIC_REQUIREMENTS = “(“CLUSTERS/ID” @> 109)”
AUTOMATIC_REQUIREMENTS = “(CLUSTER_ID = 109) & !(PUBLIC_CLOUD = YES) & !(PIN_POLICY = PINNED)”
CLONING_TEMPLATE_ID = “153”
CONTEXT = [
DISK_ID = “3”,
FILES_DS = "/var/lib/one//datastores/137/34632bac39693b558086f5715159b036:‘scriptContexto.sh’ ",
SSH_PUBLIC_KEY = “ssh-rsa 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 root@one.almg.uucp”,
TARGET = “hdc” ]
CPU = “2”
DISK = [
ALLOW_ORPHANS = “YES”,
CLONE = “NO”,
CLONE_TARGET = “SYSTEM”,
CLUSTER_ID = “109”,
DATASTORE = “dsi”,
DATASTORE_ID = “136”,
DEV_PREFIX = “sd”,
DISK_ID = “0”,
DISK_SNAPSHOT_TOTAL_SIZE = “0”,
DISK_TYPE = “FILE”,
DRIVER = “raw”,
FORMAT = “raw”,
IMAGE = “ol-ctx-vm01-disk-0”,
IMAGE_ID = “255”,
IMAGE_STATE = “10”,
LN_TARGET = “SYSTEM”,
ORDER = “1”,
ORIGINAL_SIZE = “32768”,
PERSISTENT = “YES”,
READONLY = “NO”,
SAVE = “YES”,
SIZE = “32768”,
SOURCE = “/var/lib/one//datastores/136/524d83faacb717d3138c4e6d544d7bf8”,
TARGET = “sda”,
TM_MAD = “ssh”,
TYPE = “FILE” ]
DISK = [
CLONE = “NO”,
CLUSTER_ID = “109”,
DATASTORE = “dsi”,
DEV_PREFIX = “hd”,
DISK_ID = “1”,
DISK_TYPE = “FILE”,
DRIVER = “raw”,
FORMAT = “raw”,
IMAGE = “ol-ctx-vm01-disk-1”,
IMAGE_ID = “256”,
IMAGE_STATE = “9”,
ORDER = “2”,
ORIGINAL_SIZE = “10181”,
READONLY = “YES”,
SAVE = “NO”,
SIZE = “10181”,
SOURCE = “/var/lib/one//datastores/136/9f61cdf869fa6899699e5245a9c2d852”,
TARGET = “hda”,
TM_MAD = “ssh”,
TYPE = “CDROM” ]
DISK = [
CLONE = “NO”,
CLUSTER_ID = “109”,
DATASTORE = “dsi”,
DEV_PREFIX = “hd”,
DISK_ID = “2”,
DISK_TYPE = “FILE”,
DRIVER = “raw”,
FORMAT = “raw”,
IMAGE = “ol-ctx-vm01-disk-2”,
IMAGE_ID = “257”,
IMAGE_STATE = “9”,
ORIGINAL_SIZE = “1”,
READONLY = “YES”,
SAVE = “NO”,
SIZE = “1”,
SOURCE = “/var/lib/one//datastores/136/3216608a18144b5a4ea375dd70935c70”,
TARGET = “hdb”,
TM_MAD = “ssh”,
TYPE = “CDROM” ]
GRAPHICS = [
LISTEN = “0.0.0.0”,
PORT = “6044”,
TYPE = “VNC” ]
MEMORY = “2048”
NIC = [
AR_ID = “0”,
BRIDGE = “onebr55”,
BRIDGE_TYPE = “linux”,
CLUSTER_ID = “109”,
IP = “172.16.55.1”,
MAC = “02:00:ac:10:37:01”,
NAME = “NIC0”,
NETWORK = “Barramento VDI - bridge”,
NETWORK_ID = “27”,
NETWORK_UNAME = “oneadmin”,
NIC_ID = “0”,
RDP = “YES”,
SECURITY_GROUPS = “100,101,102”,
SSH = “YES”,
TARGET = “one-144-0”,
VN_MAD = “bridge” ]
OS = [
BOOT = “disk0,disk1”,
FIRMWARE_SECURE = “YES”,
UUID = “05d04c08-5e67-44f1-99bc-46ec0ae94dbb” ]
SECURITY_GROUP_RULE = [
AR_ID = “0”,
IP = “172.16.55.1”,
NETWORK_ID = “27”,
PROTOCOL = “TCP”,
RANGE = “22”,
RULE_TYPE = “inbound”,
SECURITY_GROUP_ID = “100”,
SECURITY_GROUP_NAME = “VDI - Acesso SSH”,
SIZE = “254”,
TYPE = “IP4” ]
AR_ID = “0”,
IP = “172.16.55.1”,
NETWORK_ID = “27”,
PROTOCOL = “TCP”,
RANGE = “3389”,
SECURITY_GROUP_ID = “101”,
SECURITY_GROUP_NAME = “VDI - Acesso RDP”,
SIZE = “254”,
TYPE = “IP4” ]
AR_ID = “0”,
IP = “172.16.55.1”,
NETWORK_ID = “27”,
PROTOCOL = “TCP”,
RANGE = “5900:7000”,
SECURITY_GROUP_ID = “102”,
SECURITY_GROUP_NAME = “VDI - Acesso VNC”,
SIZE = “254”,
TYPE = “IP4” ]
TEMPLATE_ID = “178”
TM_MAD_SYSTEM = “ssh”
VMID = “144”
